Bradley25mm Posted September 18, 2019 Report Posted September 18, 2019 Does anyone know of an aftermarket detail set for the engines? Thanks Christopher
ipmsusa2 Posted September 19, 2019 Report Posted September 19, 2019 As far as I've been able to find, there isn't. Eduard produces a Big Ed photoetch package that covers the interior, seatbelts, landing gear detail, exterior and canopy masks. You also will absolutely want the white metal l.g. replacements from Scale Aircraft Conversions. Quickboost produces...and probably some other companies....offer gun barrels. Don't worry about showing the engines exposed on the model because Trumpeter doesn't provide positionable panels. But do spend a lot of time figuring out where you're gonna cram enough weight to keep the nose down. Hint: It ain't gonna be easy.
Bradley25mm Posted September 19, 2019 Author Report Posted September 19, 2019 Richard, Thanks for the reply. I’ve purchased everything you’ve mentioned above. I’m going to buy the propeller correction set as well. I’ve decided to really take my time on this one. I’ve opened up the engine panels on both nacelles already. I’lI thin the panels out with my Dremel tool. I plan on super detailing the engines, and gun bays. I’ll have to scratch build the framing around each panel attachment point, as well as a few other things. As far as being tail heavy, I glue all my models to their bases. Have you built this kit? Christopher
ipmsusa2 Posted September 19, 2019 Report Posted September 19, 2019 Chris, Haven't built the kit, but I have one. Whenever I get around to it, I'm hoping to convert it to a P-38G. Nothing like being a glutton for punishment, is there? Anyway, good luck on your project. Sounds like it'll be a spectacular model when its finished. and also an ideal entry in the 2020 Nats in San Marcos, Texas. Richard 1
dmorrissette Posted September 20, 2019 Report Posted September 20, 2019 Here's the IPMS review of the kit http://www.ipmsusa.org/reviews/Archive/Kits/Aircraft/Trumpeter_32_P-38L/Trumpeter_32_P-38L.htm Dave 1
Bradley25mm Posted September 21, 2019 Author Report Posted September 21, 2019 Thanks Dave for the review link. Christopher
Bradley25mm Posted October 29, 2019 Author Report Posted October 29, 2019 All the parts have come in. The engine covers are what I'm working on now. After they were cut apart, I thinned all the panels with my Dremel tool. Just like the Mustang I built, I'm going to pose this one in a state of maintenance as well. I've purchased mechanics from Black Dog Models, and a B-25 Mitchell crew from ICM models. The engines, and all the framing will take the most time to construct. Christopher 1
Wolfman63 Posted December 2, 2019 Report Posted December 2, 2019 That is looking like a great start! Although the figures with their heads on sticks looks creepy. LOL
Bradley25mm Posted February 20, 2020 Author Report Posted February 20, 2020 Finally got around to starting the base. I purchased Martson Matting from Tom’s Model works. I’m not going to do the entire base, but a good portion of it. I’m going to use sanded grout on the side to simulate dirt. The decorative brass plates are being made at the Trophy shop.
Bradley25mm Posted March 2, 2020 Author Report Posted March 2, 2020 I applied the final coat of polyurethane on the trim of the base. I normally only apply 1 coat. This trim has 3 coats, sanded between coats. I've laid all the photo etch Marston Matting that I have on hand. I'm waiting for the last 4 sets to come from Tom's Modelworks. The pieces are pretty delicate when you handle them. The hooks are easily bent if you bump them. I used tweezers every chance I could to reduce damage. The instructions state that you should leave them on the frets until your ready to apply them. It cut easily with scissors. The base is furniture grade plywood. I final sanded it with 220 grit sandpaper. I wiped down the plywood with a damp cloth of Mineral Spirits to get all the fine sawdust up, before gluing the photo etch down. I used Loctite super glue to attach them. I used several photos of the actual runway as a reference. The most important task is to make sure the joints are staggered when you start out. Although I used a reference line to start the runs, its not perfectly straight. Actual photos looking down the runway show that it pretty wavy. Once the surface was leveled and compacted, the pieces were put down one at a time. Each piece was about 66 lbs. Each piece measures 10ft long x 15in. wide. Once I get all the pieces laid, I'm going to apply a thin coat of sanded grout on both sides to simulate dirt. I'm going to use kitty liter to simulate small rocks on each side, The figures are a mix of Black Dog, and ICM. The tools are from MiniArt. The ladders and small table are from Black dog. The large table was scratch built from balsa wood The ammo crates, and tarps are from Value Gear. The kit itself comes with a lot of photo etch parts. I did purchase several Eduard kits to improve the interior, exterior, and gun bay. The plaques from the Trophy shop turned out great, I thought. Chris 1
ghodges Posted March 13, 2020 Report Posted March 13, 2020 Sweet! That brass really sets off those radiators. Looking forward to your next progress post! Gil
Bradley25mm Posted March 19, 2020 Author Report Posted March 19, 2020 All that's left to do now, is dirty everything up, and put it together. It always amazes me that Trumpeter will provide a detailed engine, but no way to show it. I detailed the entire thing even though some of the detail will be hidden. To simulate rubber hoses and clamps, I used electrical tape, and photo etch scrap. Since I'll be showing these, I had to scratch build the header tanks that sit on top of the reduction gearboxes. I went thru my model stash to find the thickest piece of sprue I could, heated it, and used a large razor knife handle as a jig. I dressed them up with spare parts from my photo etch stash. The "seam" that goes around the tank, is heated sprue that was stretched out. Added hydraulic lines/hoses to the landing gear. I'm using Tamiya Bare-Metal silver for the main color. After a small "mishap" with the base, I finally finished it. I used pre-mixed sanded grout, as the ground work. First thing I did was put tape where the decorative plates would go. I applied it directly to the wood with a small spatula. After every thing was smoothed out, I stippled the surface with a large paint brush. I added sifted kitty litter to a few spots while the grout was still wet. Last thing to do was carefully remove the tape while the grout was still wet. It was painted with several shades of Tamiya brown. A heavy wash of artist oils (burnt umber) thinned with mineral spirits was applied to the ground work only. After the wash dried, I dry brushed it with Naples yellow hue artist oil. Chris 1
dmorrissette Posted March 20, 2020 Report Posted March 20, 2020 I love this. Can't wait to see it done Dave
Bradley25mm Posted March 31, 2020 Author Report Posted March 31, 2020 The cockpit took quite some time with all the photo etch. The gun bay was not to bad. The resin propellers are extremely thin, but very accurate. I used white thread to simulate wiring. So far, the fit of the parts is really good. I’ve started building the framework around the engines with thin plastic sheets. Chris 1
ghodges Posted April 1, 2020 Report Posted April 1, 2020 Impressive! I hope you've contacted Lockheed about getting paid.... Gil
ghodges Posted April 12, 2020 Report Posted April 12, 2020 WOW! There is SO much there to like, from the details you added to the composition of the scene. Put a more historic background on that last pic and it could almost pass for a war time photo! Thanks for sharing this superb build with us! Gil
Bennetts Posted April 12, 2020 Report Posted April 12, 2020 This certainly turned out amazing. Well done!
WildBill50 Posted April 14, 2020 Report Posted April 14, 2020 Fantastic! The composition of the whole scene works. Great job. Bill
aAzZ09 Posted April 14, 2020 Report Posted April 14, 2020 Richard Bong would be proud of that J model Lightning! Nice work Brad! Mark
