sprueguy 26 Posted June 6, 2020 Report Share Posted June 6, 2020 (edited) This is a 1/16th sculpt I've been working on for a long time. Used some extra time off to finish it. The figure is a Marine stationed on "the fighting top" around the 1779 time frame. My painting and photography skills are some what lacking any advice would be welcomed. Edited June 6, 2020 by sprueguy 1 Link to post Share on other sites
VonL 51 Posted June 8, 2020 Report Share Posted June 8, 2020 Fantastic piece of work! Link to post Share on other sites
ghodges 539 Posted June 9, 2020 Report Share Posted June 9, 2020 Did I understand you in that this a figure YOU sculpted from scratch? VERY impressive, if so! Regardless, I like the slightly slumped stance...it looks natural for someone reaching behind themselves for something while have to balance on object in the other hand. As for the painting, I have almost no experience with figures, and would be proud of the result you've gotten. And as to the photography, the only suggestion I'd make is the same problem I usually have to conquer....more light, and from multiple directions and levels to illuminate all aspects better. Great modeling and thanks for sharing! Gil Link to post Share on other sites
sprueguy 26 Posted June 9, 2020 Author Report Share Posted June 9, 2020 2 hours ago, ghodges said: Did I understand you in that this a figure YOU sculpted from scratch? VERY impressive, if so! Regardless, I like the slightly slumped stance...it looks natural for someone reaching behind themselves for something while have to balance on object in the other hand. As for the painting, I have almost no experience with figures, and would be proud of the result you've gotten. And as to the photography, the only suggestion I'd make is the same problem I usually have to conquer....more light, and from multiple directions and levels to illuminate all aspects better. Great modeling and thanks for sharing! Gil Thanks for the advice. It's done with old spue and other scraps of plastic Link to post Share on other sites
