1/48 P-47D Razorback engine question
Can anyone tell me what Vector engine I should use on the Hasegawa 1/48 P-47 Razorback? I have the R-2800 type A/B (early) and the R-2800 C (late) engines and the headers both say for the 'D'. The Hasegawa instructions say the kit is a P-47D-10-21.
Thanks,
Jerry A.
The only appreciable difference between the 2 engines is probably in the shape of the magnetos. Here's a link to a -40 Razorback, which has round magnetos. Does it match your A/B "early" engine? If so, and since the -10 predated the -40, then that'd probably be the one to use. I think the later 2800 magnetos may have been more oblong shaped by comparison. You can also get a lot of info by Googling "R-2800 engine drawings. Hope this helps!
https://www.google.com/search?q=p-47d-10-re+engine+images&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiSgOrlrPTYAhVs3IMKHcSoDZ0QsAQIMg&biw=1583&bih=757#imgdii=5LVMyimnM9SzDM:&imgrc=Zy3RSGdsegOqCM:
Jerry, I think the major recognizable differences between the R-2800 A/B and C series engines is in the reduction crankcase between the cylinders and the propeller. The A/B series engines had a one-piece, smooth crankcase while the C series engines had two piece crankcases fastened together with a row of bolts. That should make them distinguishable. Thus, the Vector instruction that a C-series for the P-47D is incorrect and that a P-47M/P-47N is more appropriate. HTH
Thanks for the info gents! I will go with the Vector R-2800 A/B (early) with the one piece crankcase and oblong magnetos. Great link Gil, thank you! Also, noticed you did a article for Aerospace Modeler Magazine (# 8) on "Salvaging a Stoof", excellent piece & photos! What ever became of that magazine? I have all except # 11 one of the best (in my opinion) magazines around. Thanks again for guys for the info!
Jerry A.
Unfortunately, AMM folded a few years back due to financial problems. Billy Crisler (publisher, editor, and chief bottle washer) still has the itch to start it back up, but that's a tough nut to crack, especially in this age of the internet. Thanks for the kind words!
The internet has also made it tough to make any money, never mind living, writing about this hobby/business.
