Ron Bell Posted July 25, 2017 Report Posted July 25, 2017 This kit comes with markings for either the Arc Royal or the Eagle. I added the Loren Perry British Carriers PE set. The flight deck comes split in two in a way that with different parts would enable you to build the ship without the angle deck, with the slight angle this one has or with the complete larger angled deck, all of which the ship had from various re-fits. You don't get those parts, however, so you're stuck with this configuration. The single biggest challenge was this deck. To hide that seam necessitated filling and sanding over and over to get a smooth surface. In addition, the forward elevator is supplied to be in either the raised or lowered position. I wanted a closed deck, so I had to glue the elevator in the up position, which created a seam that needed similar attention. The arrestor wires are molded into the deck, so they were removed when the deck was sanded, but they are also supplied as decals, so that worked out just fine. The ship is painted as the instructions said, but since they were all in Japanese, my working out the colors may not have been 100% spot on. The aircraft come molded clear and are nicely done for this scale. They give you Seafires, Seafuries, Gannets and Wessexes (Wessexi?). Unfortunately, the first two never served on this ship and the Wessex only served in the HAS 3 version, not the one supplied. So, other than the Gannets, none of the a/c should really be used. However, I thought the deck looked a bit bare, so I fudged a bit and added the Wessexes. DSCN4687 by Ronald Bell, on Flickr DSCN4691 by Ronald Bell, on Flickr DSCN4692 by Ronald Bell, on Flickr DSCN4693 by Ronald Bell, on Flickr DSCN4694 by Ronald Bell, on Flickr DSCN4695 by Ronald Bell, on Flickr DSCN4696 by Ronald Bell, on Flickr
Rusty White Posted July 25, 2017 Report Posted July 25, 2017 Nice build Ron. Be careful; building ships is contagious!
Ron Bell Posted July 25, 2017 Author Report Posted July 25, 2017 Thanks. Coming from you that means something.
ghodges Posted July 25, 2017 Report Posted July 25, 2017 Lovely looking carrier Ron. I'd have never guessed that the deck didn't come in one piece if you hadn't mentioned all of the work it took to get it to look so seamless. Congrats! GIL
WildBill50 Posted July 26, 2017 Report Posted July 26, 2017 Great looking boat Ron. It always seems the air wings are just a hodge-podge of whatever is out there. The helos add some nice color. Bill
kidcurrie42 Posted July 26, 2017 Report Posted July 26, 2017 Looks Great Ron, Nice to see some models of the Senior Service :) With regards the two part Flight deck, The Ark Royal has the other part as her deck was slightly different, that is the only difference between the two kits if I remember correctly.... The Helo's are fine as the Eagle and Ark both carried the HAS.1 and 3, both together in later years, The HAS.I acting as plane guard and the HAS.3 was ASW. If you would like to add aircraft, check out shapeways.com they have lots of aircraft in all scales, especially 1/700, designers also take requests. John
