Wolfman63
1:350 USS Carl Vinson Project
More work on the flight deck. Yes I colored the padeyes. They came out very good. Took me a while to figure out how to do them. Also put on the few decals that I needed and started to do the elevators. Next comes the hose reels and weathering of the flight deck.
On to the pictures!
Magnificent! And just how did you paint the padeyes?
I am overwhelmed by such sensational work!
The secret is I did not paint them. I have a set of Prismcolor Premier colored pencils that I use for detailing models. I took the white one and colored the padeye's then ran a pink eraser over the deck which made the circle edges come out even. Took about 2 hours to do the deck and elevators.
Stroke of genius man. Thanks for that tip. I have a 1/500 scale Stennis I might try that on.
Looking forward to seeing more.
Kind of a slow modeling week as other things had to get taken care of. Was able to get the hose reels built, landing cables, and flight deck weathering done. Now working on the island details now.
I have had a few folks inquire on how I did the flight deck weathering. So here is how I did it.
I used black, gray, and brown pastel chalk. I first took the brown and using a balled up paper towel I rubbed the chalk on the jet blast deflectors and the area between the catapults and JBD's. I then used same method and did the area's outside the brown areas and down each side of the catapults.
I then used the same method but went over the center of the JBD's and catapults with black. The then made blotches and stains around the entire flight deck. I made a large area around landing wire #3 (This is the wire that the pilots aim for as the perfect landing wire to catch). On this large area I then used eye makeup foam pads and made streaks with black and gray to represent where the aircraft touched down. Mostly near the center of the runway and extending from wire 1 to wire 4 in a diamond pattern centered on wire 3. Finally taking a makeup blush brush I brushed the surface of the flight deck from bow to stern to blend the colors and remove any excess chalk powder. It then gets a dusted spray of matte clear coat 3 times allowing each coat to dry. The a final coat to seal it all. The dusted coats are required because if you spray a seal coat, it will pick up some chalk and give it weird streaks.
Island work continuing. The main mast is just about done. Need to tweek some of it to get everything lined up and some paint touch up. Next do all the rigging and build the radar tower that stands behind the island. On to the pictures:
Magnificent! Wow, if it weren't for the background, I could convince myself I was looking at the real thing!
I would suggest checking the forward mast part in the topmost part of the main mast. It looks to be leaning backward. It might be the angle of the pic though.
Once again, sensational work here!
Yes, they need to be adjusted to straighten them out. Will be done during the rigging.
Excellent. I figured you would have seen it. I didn't mean to presume.
Completed all the rigging on the island. I used EZ Line thin. It works great! Also start the radar tower. This is all photoetch (from White Ensign) Just need to build the antenna and then mount it to the deck.
The radar tower is done, The raft canisters, whip antenna's and starboard forward tower (scratch built) are done. Just need to add the whip antenna's and raft canisters to the port side and the anchors. This will basically complete the ship (screws will be put on after the ship is mounted to the display base). All that is left is 56 aircraft, deck tractors, Tilly crane, and the display case.
UPDATE: Was informed that the radar tower behind the island is in the wrong position. After some quick research, I have confirmed that Trumpeter has the radar tower in the wrong spot. The tower should be located at the very edge of the flight deck. This is for all Nimitz class carriers. The Nimitz 1975 cruise book clearly shows the tower at the edge.
I have relocated the tower.
BEFORE:
AFTER:
Wow! Stunningly amazing work and so quickly too! I am overwhelmed.
There is light at the end of the flight deck! The ship is basically done. The only two things left to do is to add the screw (props) once it is mounted on the display base and put the flag on it. I did not like how the flat decal flag looked. I do have some ideas on how to make the flag look more realistic. If you have any tips or tricks on making 1/350 scale flags look realistic, please let me know.
For now I will be working on the rest of the aircraft for the flight deck, the deck tractors, and the Tilly crane. I purchased the Tilly from BaconFist at Shapeways and am working on detailing it now. The last two pictures are the boxes of aircraft left to build and the Tilly crane without detailing.
I am not the best photographer and due to the lighting it is difficult getting a good picture with the compact digital camera. I do plan on having professional pictures taken once it is complete.
Wow oh wow! That is so outstanding! The lighting is magnificent and really enhances this model beyond measure. Way to go man!
Special Update! Since the ship is done I now need to work on the filling the flight deck. With all the detail I added to the ship, it only makes sense to continue with details.
I ordered the Tilly crane from BaconFist on Shapeways (3D printed accessoriesfor Nimitz Class carriers)
This is how it arrived:
And here it is after 9.5 hours of detailing.
Now to start work on to the deck tractors.....
Working on filling the flight deck continues. Here are the deck tractors for the flight deck. These are the Black Dog deck tractor set. The only assembly was the wheels. The decals are from Star Fighter. Next up is to start working on the many aircraft for the flight deck.
Those all look so incredibly awesome! Wow! They will really liven up the deck!
Work is progressing on filling the flight deck. The EA-6B's and the SH-3's are done. So there are only 48 more aircraft to do. I also received the brass plaque which will be mounted on the base of the display case. The final position of the aircraft will be done after all of them are built. Here are the latest pictures:
The S-3A's for the flight deck are now complete. Working on the E-2C's now. They are built just need to paint and decal them this weekend.
Little late on latest update. Between Christmas and a minor health issue I am hoping to get back to the rest of the aircraft. Here are the E-2C's from VAW-114 on the flight deck. I will be starting on the A-6E's next after I set up my new work bench that my awesome loving Wife got me for Christmas. (Pictures will be posted later) Now on to the E-2C pictures:
As promised, Here are pictures of the new work bench.
I had a small wooden drafting/hobby desk. Worked great for about 10 years. For Christmas my Wife bought me a new one. It's 35% larger surface area and steel supports so it is very stable. Used it the first time last night working on 1/350 A-6E's for my Vinson project.
Here is what I used for 10+ years:
Here are pictures of my new one. I like the tray in front. Very handy.
Here is one of the new large Xacto self-healing mats:
And here is it in use:
Now plenty of room to build:
