sprueguy Posted November 18, 2018 Report Posted November 18, 2018 Here is the beginning of a new figure. When completed it will be a 1/10th bust of a US Army soldier from the Vietnam war around 1968/69 time frame. I used the old Monogram 1/10th Vietnam war statue as my base. The different colors are from various types of plastics melted, such as the orange, blue, and pink are from use razors, the green is a plastic spoon, and the rest are from sprue. The helmet is molded from plastic forks. This is intended to be a SBS to show another way to use left over plastic (sprue).
WildBill50 Posted November 20, 2018 Report Posted November 20, 2018 Amazing! How do you melt all of this stuff and have it bind with each other? It it just a matter of sculpting the rest then? Bill
sprueguy Posted November 20, 2018 Author Report Posted November 20, 2018 (edited) Bill: the picture above kind of shows the process used. In this case the helmet. Shown are the original sculpt, the silicon mold, the 1st copy, and finally the sanded finish copy. The heat from the toaster oven is enough to melt the various plastics together. The picture below shows the basic oven setup. I use the "Pam" as my releasing agent. The bottom picture shows more work on the helmet. It was cast using plastic cutlery. The above picture of a proportional divider, scaled picture of an M16a1, and a piece of sprue. The drawings and the divider are the things used to make the rough m16. The first picture shows the basic step needed to sculpt anything in plastic. I use a basic wood burning iron, with a flattened tip that is sharped to a knife's edge. I simply slice into the sprue, and build into a basic shape with the soften plastic. The stock of the m16 being worked on shows the melted sprue applied to the stock sprue length Here is the piece ready o be molded The mold is made in two pieces with DAP 100% s silicone. Here we have the base piece placed on modelling clay, It will be pushed into the clay to the half way point. I'll spray it with a cooking spray, this is to prevent the silicone from sticking to the piece. Once the mold is settled, I'll cut a section of sprue using a set of wire cutters. I'll place the bits of sprue in the mold. Heat at about 400 degrees for thirty minutes. Set aside to cool. As you can see you will have lots of work on the piece before you have something finished. This picture shows the original base piece, one piece with the flashing cleaned up, and a little bit of detail work done. The last piece is just out of the oven. This is not a process for the faint at heart, but is well within the abilities of most modelers. The molding part could be used to copies of just about any item you wished. I would like to say after doing this for decades know, I've never seen any commercial use for this. It's fun and I like doing it. Good luck This is just a basic overview of what I do. If you have questions please feel free to ask.... Edited December 3, 2018 by sprueguy more details
WildBill50 Posted December 6, 2018 Report Posted December 6, 2018 My hat is off to sir! Great pictures and explanations for the way you do what you do. Keep it coming. Bill
sprueguy Posted December 18, 2018 Author Report Posted December 18, 2018 Some updated pics, kind of gives an idea where I'm going with this. Pictured are the arm positions and some of the TA-50 equipment of the figure, not pictured are the grenades, AN-PRC25 field radio, butt pack ect….. 1
