MigMan Posted July 13, 2016 Report Share Posted July 13, 2016 Hey Guys, I'm a relatively new member and this is my first post on this forum!! I have heard that Tamiya's primer is one of the best out there and I would like to use it but it is a lacquer based primer and I use mostly acrylic paints. I understand that you can layer (but not mix together) paints of different bases but they have to be layered in a specific order. For instance: Start with a lacquer based primer; then preshade with an enamel paint; then you could lay down an acrylic base color. I don't know if the above statement is correct and that is what I am asking you: Is it correct? Also, if you were to paint the layers listed above, would it be dangerous to maybe add a layer of enamel based paint on top of the acrylic base? (as if you were doing a camouflage scheme?) Thanks in advance for your sage advise!! Joe Miriani Link to comment Share on other sites More sharing options...
Ron Bell Posted July 13, 2016 Report Share Posted July 13, 2016 I'm not a chemists, but this is what I've always heard. Never put lacquer over anything. You can put anything over lacquer. Not sure about the interaction of the other two. I do know that whatever primer you use, make sure it's complete set, not just dry, before you over coat it because if you don't, you may get crazing as different base paints can set at different rates and one will pull the other apart. Link to comment Share on other sites More sharing options...
SkyKing Posted July 13, 2016 Report Share Posted July 13, 2016 (edited) The general rule is: "Acrylic" (i.e., water-based) over enamel (oil-based) over lacquer (lacquer-based). NEVER enamel over acrylic and NEVER lacquer over anything. This is a rule which I have obeyed for years, and it has never let me down. Having said that, however, there do appear to be some modern "acrylics" that are robust enough to stand up to the application of enamels over them. I can't tell you which ones, because I shy away from "acrylics." I put "acrylics" in quote because "acrylic" means different things to different people. There are water-based "acrylics" (which are technically enamels), and there are "acrylic lacquers." The latter are lacquer-based but their pigments are acrylic polymers. You can use Tamiya primer for just about anything without fear. And enamels need not be restricted to pre-shading; you can apply enamels over enamels without any problems. And you can also pre-shade with water-based acrylics if using them for your base colors. Ron's advice is good. I usually allow any paint I apply to dry/cure for a week before applying more paint on top. If you can still smell paint on your model, the paint still isn't dry/cured. Edited July 13, 2016 by SkyKing Link to comment Share on other sites More sharing options...
Wilky Posted May 9, 2017 Report Share Posted May 9, 2017 I have used Testor's Dullcote and Glosscote, both rattle can and brush, over enamels and haven't had any problems. Link to comment Share on other sites More sharing options...
PeteJ Posted May 9, 2017 Report Share Posted May 9, 2017 (edited) Simple explanation is this. All paints are made of 3 basic components. Solids or pigments, binders and solvents or thinners. The key difference is the binders and solvents. These are the basic "glues" that make paint stick. The binder is the solid glue and the solvent dissolves it to make it liquid. Lacquer's solvents are based primarily on acetone and MEK with some other solvents thrown in. These solvents are the "hottest" and will generally dissolve almost anything. The "other" solvents and proportions are what differentiate various Lacquer thinners. The best automotive lacquer thinners have more of the expensive solvents and less acetone in them. They do a better job of dissolving the binders and pigments, but the more of these solvents the more expensive they become. This is why there is a significant difference in the price and action of auto paint shop and Home Depot lacquer thinner. Home Depot is mostly acetone. High end thinners are also more prone to attacking plastic. Enamel thinner is mostly naphtha AKA mineral spirits or paint thinner. This is a slightly less aggressive than the solvents in lacquer thinner. Depending on the mix and the lacquer, enamals it can be used over lacquer. Acrylic paints are commonly referred to as "water"based but the reality is that the primary solvent is alcohol. That is what gives acrylics that slightly "sweet" smell. Because dilute alcohol will not generally dissolve lacquers or enamels it can be used over them. Also some acrylics can be thinned with lacquer thinner. Tamiya recommends this when you want a "harder" finish. Doing this however, precludes using it this way over enamels. Now a bit about acrylic as used in paint. Acrylic correctly describes the pigments used, not the thinners. Acrylic is a synthetic pigment, not a natural mineral pigment such as titanium(white) or ocher(red) which occur naturally. Before the advent of acrylics, natural pigment came mostly from the ground and were dug up and crushed for use in paint. This word is very much misused to describe a type of paint but it has become a part of the general lexicon and as such we are kind of stuck with it. Now, what can be used over what? Alcohol based over all. Naphtha over lacquer but not alcohol and lacquer on the bottom. Having said that here comes the caveat. Because 91% alcohol used straight undiluted, will dissolve some lacquer paint, if given enough time, all of these have compatibility issues. Laid down in light coats so the solvents will evaporate quickly, they can all be used with each other. If the solvent doesn't have time to attack the layer beneath, then no issue. Lay on a thick coat and you have problems. I mentioned compatibility. This is when you get the wrinkling and the paint bubbles up. This occurs as a result of paint shrinkage as it cures. All paints shrink some as they cure. That is the nature of the beast. When you get two paints that shrink at different rates then you get the wrinkling. It is made worse because if they shrink at different rates, they also expand at different rates. When you have a cured layer and you spray a new layer down, if the old layer absorbs the new thinner it will start to expand and as the two shrink back at different rates, then you get wrinkles. There is no formula to tell you when this will or will not happen so you can only do a test shot to see. I hope this helps! Edited May 10, 2017 by PeteJ 1 Link to comment Share on other sites More sharing options...
Rusty White Posted May 9, 2017 Report Share Posted May 9, 2017 Knowledgeable explanation Pete. Well done. Link to comment Share on other sites More sharing options...
Wilky Posted May 9, 2017 Report Share Posted May 9, 2017 Very informative explanation, but I was just stating that Testor's Dullcote and Glosscote can be used over (I should have said Testor's) enamels and acrylics even though it is lacquer based. I don't know if you can use it over other manufacture's paints. As for the 91% alcohol, I found that out the hard way on enamel paint when I was trying to do some filtering and washes. I used the alcohol to clean and moisten the paint brushes and it did a number on the paint! Ron W. Link to comment Share on other sites More sharing options...
bobbenko Posted May 19, 2017 Report Share Posted May 19, 2017 As a retired Chemical Engineer, I felt compelled to add some clarification to PeteJ's good explanation. The "sweet" smell of the acrylics is more likely to be from "glycols" that are added to the paint to get the paint to flow smoothly. Other glycols that you know are automotive antifreeze (ethylene glycol). The acrylics that PeteJ mentioned are not pigments but the binders in acrylic paint. They are long spaghetti-like molecules that glue the paint pigments to the surface that you are painting. Acrylic clear coat is just acrylic binder and solvent; no pigments. The pigments that PeteJ mention come in two categorizes: Inorganic and Organic. The inorganic pigments are, as PeteJ says, natural minerals. Ground up dirt if you will. Examples are Titanium White, Yellow Ochre Ultra Marine Blue. The organic pigments are usually man made chemicals or molecules that were originally extracted from crude oil or coal tar. Some of these were first discovered by German Chemists in the late 1800's. Examples are: Phthalo Blue, Phthalo Green, Napthol Red. BoB Link to comment Share on other sites More sharing options...
PeteJ Posted May 20, 2017 Report Share Posted May 20, 2017 As a retired Chemical Engineer, I felt compelled to add some clarification to PeteJ's good explanation. The "sweet" smell of the acrylics is more likely to be from "glycols" that are added to the paint to get the paint to flow smoothly. Other glycols that you know are automotive antifreeze (ethylene glycol). The acrylics that PeteJ mentioned are not pigments but the binders in acrylic paint. They are long spaghetti-like molecules that glue the paint pigments to the surface that you are painting. Acrylic clear coat is just acrylic binder and solvent; no pigments. The pigments that PeteJ mention come in two categorizes: Inorganic and Organic. The inorganic pigments are, as PeteJ says, natural minerals. Ground up dirt if you will. Examples are Titanium White, Yellow Ochre Ultra Marine Blue. The organic pigments are usually man made chemicals or molecules that were originally extracted from crude oil or coal tar. Some of these were first discovered by German Chemists in the late 1800's. Examples are: Phthalo Blue, Phthalo Green, Napthol Red. BoB Thanks for the clarification. Always good to get better information. So, if I understand this right, acrylic is a binder that can be used in all three types of paint. It still makes me nuts that we refer to water/alcohol based paint at "Acrylic" although I don't know what other word we would use for it. Shellac is the earliest alcohol base "paint" that I am aware of and what we refer to as "Acrylic" is definitely not a shellac. That is the excretions of the Lac bug, dried and dissolved in ethanol. I seem to recall Earl Schibe adding "acrylic" to auto paint for and extra fee. Link to comment Share on other sites More sharing options...
