TimDarrah Posted October 10, 2012 Report Posted October 10, 2012 I had a problem that I've never seen before. I used my Revell of Germany kit decals on my AR. E555/1 over a gloss coat and used Solv-a-set on them. One of my decals had an air bubble, or so I thought, I cut it and re-applied Solv-a-set to it, the bubble didn't go away and that area (inside the bubble) turned white. Any ideas on how I can fix it? I have a good paint job on and don't want to have to strip and re-spray that area. Thanks, Tim
Mark Deliduka Posted October 10, 2012 Report Posted October 10, 2012 The bubble may already be gone, and the white is a reaction of the Solvaset to the Future. Happens to me alot. Try applying some Future with a brush over the 'bubble' to see if it wicks underneath to cover the white area. If that happens, then the Future should dry clear again. Mine always does when I re-apply some over any solvaset reactions. Let me know what happens; maybe also post some pics to show the issue. Hope this helps.
Ron Bell Posted October 11, 2012 Report Posted October 11, 2012 What you probably have is called "blush". Usually when it thoroughly dries, it goes away. However, being as its under a decal it may take quite a while. Wait a few days/week to see what happens. If it stays white, try Mark's idea. I say wait because once you apply the future over the decal, it's sealed and underneath it may never dry right and the decal won't respond to any other attempts to fix it.
DaveDeLang Posted October 11, 2012 Report Posted October 11, 2012 Since you said it turned white, I'm guessing it's a clear area? Can you cut away the decal film? That way you can get a second dab of future onto the whitened area without the decal film impeding it.
Dreamsof51 Posted October 25, 2012 Report Posted October 25, 2012 If your gloss coat is future as others have stated, I have a tip thats a bit late but I'll give it anyway. When I use future I never use solvaset. I ruined a nice project doing that when the white spots you described appeared under my decals. I've found micros decal set doesnt react that way. What I normally do is use a diluted mix of water and future as an undecoat before I place the decal. I would second the future into the bubble trick to fix what you have.
