dcaponeII Posted August 17, 2009 Report Share Posted August 17, 2009 I built these two vehicles from the Revell 1/48 Mercury plus RealSpace Models Resin conversion. Shepard's Freedom 7 uses the shell from the resin set along with the resin nose and LES components from the kit and the resin set. The cross braces are stretched sprue. The heat shield and retro pack are castings of the Revell kit parts which will be hidden when the vehicle is mounted on the Redstone that is currently under construction from two Glencoe Jupiter C vehicles. Sigma 7 was built using the kit shell, the resin on-orbit nose from the RealSpace set and a bit of scratchbuilding in the interior. Link to comment Share on other sites More sharing options...
Mark Aldrich Posted August 17, 2009 Report Share Posted August 17, 2009 Very nice work indeed! Link to comment Share on other sites More sharing options...
dcaponeII Posted August 17, 2009 Author Report Share Posted August 17, 2009 Thank you. I've started on the Gemini Spacecraft next and then I'll get to the Redstone Booster conversion. I don't like having partially built kits floating around and the Gemini came with the Mercury kit. Link to comment Share on other sites More sharing options...
Roktman Posted August 22, 2009 Report Share Posted August 22, 2009 Very nice job! Link to comment Share on other sites More sharing options...
dcaponeII Posted September 15, 2009 Author Report Share Posted September 15, 2009 The Sigma 7 didn't place at Ft. Worth this past weekend but the porthole version took first place mounted on a Redstone Conversion I did using two Glencoe Jupiter C kits and some scratch building. Here's a photo from the contest of the Redstone. Link to comment Share on other sites More sharing options...
TimHortman Posted October 4, 2009 Report Share Posted October 4, 2009 Nice work Donald - thanks for sharing! Link to comment Share on other sites More sharing options...
