Built OOB because it's nice enough without any aftermarket. I used MRP-425 IJNAF D2 (Black Green) and Tamiya lacquer IJN Light Gray for the fuselage. The cowl is MRP-432 IJNAF Q1 Cowling Color. The prop is MRP-431 Propeller color, the interior is MRP-430 IJNAF M0/M1 Gray-Green and the Aotake is MRP-410 Aotake Blue Primer. Need to take a break before I work on the FineMolds A6M5.
Excellent looking build that shows off the Zero's classic lines very well! Did you have to apply the Aotake over a silver base, or did you apply it directly over a primer coat?
Thanks Gil! I experimented on another kit and it worked so I didn't prime this one. I used the Mr. Paint and Tamiya lacquers straight on to the bare plastic.
