AP40rocktruck Posted May 30, 2024 Report Posted May 30, 2024 I scratch built this 1/3 scale model in 1987 during my apprenticeship, worked mainly in polycarbonate, ABS, aluminum, mild steel, and brass. Some WEP (water extended polyester resin), Wren board and copper. It took over 350 hours to complete, X, Y & Z table movements worked when first built, time has sized things up a bit, but it is still nice to have in my collection. Cheers Rick
ghodges Posted June 2, 2024 Report Posted June 2, 2024 DANGGGGG......... When you said when you introduced yourself you were a "professional material modeler" and posted this pic I thought is was to show a piece of your machinery in your shop that you use for work.... NOT THAT THIS WAS ONE OF YOUR BUILDS! I am suitably agog! Thanks for sharing! Gil 1
dmorrissette Posted June 3, 2024 Report Posted June 3, 2024 Sweet. Similar to the mill I learned the basics on. Dave 1
AP40rocktruck Posted June 8, 2024 Author Report Posted June 8, 2024 On 6/2/2024 at 6:59 PM, ghodges said: DANGGGGG......... When you said when you introduced yourself you were a "professional material modeler" and posted this pic I thought is was to show a piece of your machinery in your shop that you use for work.... NOT THAT THIS WAS ONE OF YOUR BUILDS! I am suitably agog! Thanks for sharing! Gil Thank you kind sir. I had a blast back in the late 1980's building it. Still have this in a crate in my workshop, still waiting for a suitable display. Cheers
AP40rocktruck Posted June 8, 2024 Author Report Posted June 8, 2024 On 6/3/2024 at 8:08 AM, dmorrissette said: Sweet. Similar to the mill I learned the basics on. Dave I learned on a Bridgeport belt drive J head, 8 speeds to do everything. When I built this model, I did much of the milling on the actual Lagun. Nice machine, big 2.5 hp motor, the variable speed head was a nice treat back then. I now teach machining fundamentals, manufacturing and metallurgy at a local college. Currently we have 8 vertical mills, 4 generic VS head machines, 3 Bridgeport's and a massive Wells-Index with a 56" table. Cheers
Jmarc Posted June 16, 2024 Report Posted June 16, 2024 That is an super cool project , well done SIR .. 1
