noelsmith Posted June 9, 2021 Report Posted June 9, 2021 Has anyone got a 3D pen? Comments on how useful it might be for modelling and plastics used would be welcome.
ghodges Posted June 10, 2021 Report Posted June 10, 2021 (edited) Don't know....I always thought it might be neat to "draw" a line of thin plastic into a seam to fill it. However, not sure how workable the "plastic" being extruded is....I know some 3D plastic is quite rough and very tough to "smooth out". It might work very well in trying to draw weld bead seams onto armor models, where smoothness is much less of an issue. In both of those cases I'm not sure if there's a short time where the extruded plastic is soft/molten enough to adhere on its own, or if you'd have to draw your desired item and then glue it in/on. Gil Edited June 10, 2021 by ghodges 1
