thought i'd share a few photos of my first major diorama build. this took me most of last winter to finish and most of the last month to redo. long long story. I pretty much had an epic failure with the water effect, (woodland scenic realistic water) 100% my fault but with the help i received from woodland scenic,thanks beth, i tore out the water effect and reworked the entire stream and shore. most of the diorama was constructed using found material outside. some vegetation from the dollar store and some woodland scenic. the case i made out of 4 one dollar picture frames from the same store.
thanks for looking
Edited by Bubbajoe
Looks good Joe! The overgrowth around the statue really helps carry over the "jungle" setting and the pose of the figures also conveys the stealth and edginess of their mission. Thanks for posting!
Great joe,
I to would like to see some construction in progress photos. Love the Dio.
Chris G. :Smile_sceptic:
Outstanding display.. love the since of proportion between the figures and the stone face..just has that feel of hot and muggy again great work....
thanks for the comments, i appreciate it.
jim ,i wish i had taken photos of the steps i took in making the case but i didn't. here is a side view of the case
i built the diorama to fit the case. as i said i used 4 frames i picked up at the dollar store, my favorite hangout to find modeling supplies. construction is pretty straight forward. i used full pieces of glass that came with the frames for the top and front. the cardboard backing was used for the back and bottom. 2 full pieces of glass form the last 2 frames were used for the sides. measure the width of the frame taking into account the thickness of the front piece of glass and the back piece of card board. mark your glass and draw your line.i used a corked backed ruler , helps keep it from slipping on the glass. i used a cheap glass cutter i picked up at the local hardware store, think i paid 5 dollars for it. tricky part is scoring the glass. you can only score glass one time. do not try to score it over and over ,it ruins the cutter. use even pressure when you make your pass with the cutter, start at the very edge and run it off the edge. take the ruler and place it under the glass and line it up with the score. then press down on the glass, should break clean. use some wet/dry paper to smooth the edge. take the frame that will be the top and silicone the glass in place. once dry you can now assemble the cases sides. if all the measurements are right .it will fit nicely in place. if your glass is off a bit. you can always trim the back panel . if the glass is short. well you'll need another piece of glass. run a small bead of silicone around the inside edge of the frame and fit the pieces in place, tape the corners to keep the case square. once dry, your case is complete. i used small screws to attack the diorama into the case, you can silicone everything and make it permenent ,but i've already taken the duo out once and redone the water, so i'd suggest to give yourself a way into the case if needed down the road. i was going to use styrene and add corner pieces but i like the clean lines of just the glass. you can also use a full piece of glass for the back if you want a full 360 display case. sorry for the novel. i tend to ramble.this is really very easy to build. i practiced cutting a couple of spare pieces of glass to get the hang of it.you can't beat the price for a IMHO a pretty nice look case. hope this helps
Edited by Bubbajoe
Guest PetrolGator
Be honest. Were you inspired by "Legends of the Hidden Temple?"
Chris, here are a few photos of the build. i deleted a few due to limited space on photo bucket. i actually built the dio around an aquarium ornament i picked up in petco. i was there getting dog food and walked down the aquarium section and spotted it.
Edited by Bubbajoe
Joe,
Thanks for posting those in-progress shots. I was wondering where you came up with the budda face. Very cool.
  • 1 year later...
I wish your photo files were bigger, it's hard for an old guy like me to take a look. As far as I can see, this looks like great work. thanks for posting.
OK, this post is from 2014....ooops..
It's hard finding new post.
Edited by spiralcity
