Bought an Oral B Cross Action Powered Toothbrush with interchangeable head that has one set of bristles that vibrate on a circular motion and another back and forth.
1. Remove the bristles.
2. Draw half inch circle on the back of sandpaper.
3. Cut out the circle.
4. Get some double sided foam tape.
5. Place smooth side of sand paper on one side of double sided foam tape and trim it.
6. Stick on the spinner head.
7. Use piece of tape and write down the grit.
Edited by stefanwest
