Weedeater Posted November 8, 2010 Report Posted November 8, 2010 (edited) As James noted above, the canopy shape issue is with the E-3 kit, and Eduard has corrected the shape and will issue the corrected canopy in their E-4/E-7 kit. The E-1 canopy is correct.... Ralph Ralph and all, Has Eduard said anything about replacing the canopies on the alreadfy issued kits? The last post I saw on the subject indicates "No". However, I don't know if they've re-thought that....it would be the right thing to do. I guess the answer will come in one of their newsletters.... Ralph Ralph, David, and All, - I recently acquired Eduard's Profipack issue of the Bf-109E-4, kit number 3003. 1. Was this one of the kits with the effected canopy? 2. If so, did they eventually correct the problem in this kit? 3. And what do I look for to confirm whether or not I got one of the "corrected" canopies? 4. If they did not correct this canopy, where do I go to find the "corrected" replacement? Thanks for your help, in advance. Edited November 8, 2010 by Weedeater
adfogel Posted November 14, 2010 Report Posted November 14, 2010 You're good...only the E-3 had teh incorrect canopy. Eduard offered a free replacement earlier this year. Later, Lee
ghodges Posted November 14, 2010 Report Posted November 14, 2010 Pardon my ignorance here (a common theme for me! ), but are we mixing up scales here? The original post concerns the 1/32 109E kit. I thought the Profi-pack kits were 1/48? Do both scales of 109Es have the same canopy issues? Or have the issues been solved for one or the other scales, or both? Thanks! GIL
TheWalrus Posted November 15, 2010 Report Posted November 15, 2010 Ralph, David, and All, - I recently acquired Eduard's Profipack issue of the Bf-109E-4, kit number 3003. 1. Was this one of the kits with the effected canopy? 2. If so, did they eventually correct the problem in this kit? 3. And what do I look for to confirm whether or not I got one of the "corrected" canopies? 4. If they did not correct this canopy, where do I go to find the "corrected" replacement? Thanks for your help, in advance. Eduard had a box of the corrected canopies in baggies at Phoenix. Free to anyone needing one. These are 1/32 scale. I know because I picked one up and am looking a it right now. It has two sets. One has a hole in the windscreen and has a telescopic site included. for that version of windscreen. Site opening is on starboard side of front panel lower corner. If you need the replacement you should contact Eduard directly via email on their site. D. Goudie 6340
