thevid Posted June 16, 2021 Report Share Posted June 16, 2021 I have a problem gluing the wheels so that the flat part sits correctly. It I use CA glue it sets to quickly and if I use something else it does not set at all. Any suggestions? Thanks, David Link to comment Share on other sites More sharing options...
Stikpusher Posted June 17, 2021 Report Share Posted June 17, 2021 Try a five minute epoxy. That will give you the time fudge factor to position the wheels properly. On a tail dragger, that’s pretty easy, but on a tricycle nose gear type, you may want to prop up the tail during the setting time to insure that the nose wheel ends up correct. Link to comment Share on other sites More sharing options...
thevid Posted June 17, 2021 Author Report Share Posted June 17, 2021 1 hour ago, Stikpusher said: Try a five minute epoxy. That will give you the time fudge factor to position the wheels properly. On a tail dragger, that’s pretty easy, but on a tricycle nose gear type, you may want to prop up the tail during the setting time to insure that the nose wheel ends up correct. Excellent idea! Thanks. Link to comment Share on other sites More sharing options...
