Narampa
Please Help Need Cutty Sark plans
I have a Cutty Sark kit missing the plans. I believe that it is a very old kit as I cannot locate it in the downloads section of Revel.
If you have a set and can help me or maybe you have downloaded them and would be able to forward me a copy I would be forever in your dept!
THE KIT # IS 0399
Thank you
49 minutes ago, SoftskinFan01 said:
Hey, Lawrence. Not sure if this is what you're after or not:
https://cuttysarkdrydock.wordpress.com/2011/09/23/the-cutty-sark-instruction-sheets/
I hope it helps!
Gary
Thanks Gary this should be fine I have referenced the plans with the parts trees, and everything looks good.
Thank you so much I really appreciate your help. I am moving you to the great people I have met on the net category.
I see the plan is from 1974!
On my Revel box it says copyright 1974. From the condition of the box it looks that old.
I am lucky that all parts are in bags and sealed.
So it should be a go!
Once again thank you
Lawrence
Edited by Narampa
Adding information
So glad I could help, Lawrence! I have gotten a TON of help and advice from fellow modelers. Glad I could contribute just a bit.
Good luck with the model!
Gary
Lawrence, as an addition to your Cutty Sark requests, besides the kit instructions you are looking for there is a fine set from George Campbell from the Cutty Sark itself
Go look at the ships forum on the Fine Scale Modeler website.  There is a terrific build thread on the Revell Cutty Sark there....  It seems to be the place to go for plastic sailing ships....
