Wolfman63 Posted December 2, 2018 Report Share Posted December 2, 2018 I have added a new tip on my blog on cleaning and polishing clear parts as well as removing scuffs or unwanted seams using Meguire’s PlastX cleaner and polish. The photos are the before and after on removing scuffs from a B-17 nose and removing the seam on a modern jet canopy. I prefer doing this rather than dipping in Pledge Future. The clear parts appear clearer with a lot more shine and resist dust when sitting on a shelf for a while. You can see a detailed step by step page on my blog at https://davidsscalemodels.com/tips-and-tricks/how-to-repair-clean-and-polish-clear-parts/ Link to comment Share on other sites More sharing options...
PeteJ Posted December 2, 2018 Report Share Posted December 2, 2018 I concur! Not everything is cured with a dip in Future. Over the years, Tamiya has produced automotive models with clear body shells. They did this by simply putting clear plastic in the molding machines. The main problem with this is that on the opaque bodies the ejector pins are hidden from view. On the clear bodies, they are very clearly(no pun intended, well maybe) visible through the body. The only way to eradicate them is with sanding and polishing. Then a coat of future to seal in the decals may be in order. Link to comment Share on other sites More sharing options...
Mississippivol Posted December 2, 2018 Report Share Posted December 2, 2018 Thank you for that! Saves some issues I've been having with dipping. Now if I can remember to remove the seam on the inside before sanding the outside multiple times, I'll be a million bucks! Link to comment Share on other sites More sharing options...
