The iconic Mitsubishi A6M Zero was the Imperial Japanese Navy’s primary carrier-based fighter plane from 1940-1945. Over 10,000 of these ubiquitous fighters were produced, with the A6M5 Type 0 Model 52 being the last and most effective model. Scale Aircraft Conversion has produced its famous white metal landing gear for the A6M5/5a Zero in 1/48 scale. As aircraft modelers well know, aircraft models displayed on their landing gear are susceptible to damage from the weight of the model, especially on styrene landing gear.
Scale Aircraft Conversion has had the solution since 1990. Their white metal landing gear is designed to bear the weight of the model and complement the detailed non-load bearing plastic parts. Their extensive range covers white metal landing gear from 1/144 to 1/18 scale aircraft.
View the full review
