IPMSUpdates Posted February 13 Report Posted February 13 This accessory kit contains three direct replacement pieces for the Monogram Catalina kit. There’s one piece of the breaching gear that isn’t included with the kit. That is the strut for the rear tail wheels. You will have to use the kit part for this. The level of detail is nice and representative for a 1/48 scale kit. The gear itself in real life is relatively simple, meant to be attached in the water. There was a little bit of cleanup to be done and two pieces of long, thin flash from the molding process had to be cut off. General flash on the parts was minimal and they cleaned up easily. I didn’t note that the tail wheel support was extremely soft until after I started working on it. Just scraping flash off with the #11 Blade caused it to bend. View the full review
