I have been using UMM razor saws for years to cut resin and plastic with great results. Since I build larger resin figures, sometimes the fine blades and smaller saw blades take a while to cut through. Also, with the blade being sandwiched in the middle, you have a limited depth to cut. The new ultimate razor saw addresses many of these issues. First, it is a double-edged blade with course on one side and fine on the other so you have options. Second, with the blade being attached on one side, you have much more depth.
One feature that is very cool is that the blade is attached by an allen wrench and that is attached to the handle, easy to remove and use and hen stow back so no looking for the wrench.
View the full review
