IPMSUpdates Posted January 19, 2024 Report Posted January 19, 2024 The Item If you want to bring your 1:48 scale Curtiss SNC-1 Falcon II Aircraft model kit to the next level, this excellent white metal cast detail set is just the thing for you. This 14-piece complete gear set with struts not only provides sturdy, fully detailed parts replacements, but they are specifically designed to fit the attachment points of the Dora Wings model. Remove the parts from the casting stubs so as to avoid bending them. As with other SAC sets, there are minimal casting seams on the parts that will need to be removed. Simple scraping, filing, or sanding makes for easy clean-up. After removal from the casting stubs, the parts can be carefully polished with a rotary tool brush, then primed and painted. Because of their malleable nature the parts can be gently bent for a proper profile and perfect fitView the full review
