Does anyone have a simple method of making the ignition harness and pushrods for aftermarkjet engines such as Quickboost make? Pushrods might be fairly easy but the harness presents more of a problem being circular, etc.
Solder might be the easiest method for the ignition ring...it's relatively soft and easy to make clean circular bends. Then drill the appropriate holes in the ring of solder, and use smaller guage wires for the ignition wires. Plastic rod would probably be my choice for the pushrods.
There are those here that are far more talented and more experienced than I am, so I'm going to be watching for the other responses to this, too!
