stevefaxon Posted May 18, 2012 Report Share Posted May 18, 2012 Hi folks, can anyone tell me what scale these really are? The X Wing seems close to 1/48..but a bit big? The Darth Vader Tie Fighter looks like 1/32? Link to comment Share on other sites More sharing options...
ewahl Posted May 18, 2012 Report Share Posted May 18, 2012 Hi, Steve, The best way to do this is to look up dimensioned three-view drawings in some reference book. Find a dimension on the drawing (wingspan or fuselage length would be best) that you can then measure on the model. Do a little math on your calculator. Presto, you have the scale. Well, almost. The assumption is that MPC/AMT made kits that were genuine exact miniatures of the filming models and/or had the exact same proportions as the drawing. Test this theory on as many dimensions as you can between drawing and model. You may get a range of numbers for scale, so pick one that appeals to you. One extra thought: Convert the dimensions on the drawing to decimal inches. Measure the model in decimal inches. Divide the model decimal inches into the reference decimal inches, and the answer equals the scale. Good luck. Ed Link to comment Share on other sites More sharing options...
stevefaxon Posted May 18, 2012 Author Report Share Posted May 18, 2012 Hi Ed, thanks for the reply. That was what I tried first, but after spending a bit of time googling I failed to find any dimensions, I found some drawings......but nothing that would quote any measurements. I'm sure there must be a book somewhere with detailed drawings in it, I just don't want to buy one for these kits and thought someone else here may have already run the numbers? Thanks again, I'll keep looking............ Link to comment Share on other sites More sharing options...
RGronovius Posted May 18, 2012 Report Share Posted May 18, 2012 Steve, Starship Modeler's Star Wars Scale Listing calls the original MPC X-Wing 1/42 scale and the original MPC Darth Vader TIE Fighter as 1/36 scale. http://www.starshipmodeler.com/starwars/swars_scales.cfm Link to comment Share on other sites More sharing options...
stevefaxon Posted May 21, 2012 Author Report Share Posted May 21, 2012 ka-ching !!! I knew there would be someone out there who had this sort of info, thanks to ALL who replied, you guys are great Link to comment Share on other sites More sharing options...
RGronovius Posted May 22, 2012 Report Share Posted May 22, 2012 Fine Molds has started to release some 1/48 scale starships, the X-Wing, Y-Wing, TIE fighter (regular one) and Snow Speeder. Link to comment Share on other sites More sharing options...
