need some help with a phantom
burner12
I'm trying to make a VF-111 sharks mouth decal. The problem I have is that the mouth goes on a double curve the radome and the IR sensor
below. How can I construct it so it will fit on both curves equally?
Edited by burner12
Superscale sheet # 48-73 has the sharkmouth your after, maybe someone here has this sheet and can help with the layout, or willing to trade
How about covering the radome in Tamiya tape as smooth as you can get it.
Draw the shark mouth on the tape.
Remove the tape without disturbing the drawing
Make the decal pattern from the drawing on the tape. You might have to slit it a little to get the compound curved surface to lay flat.
You could draw only half of the shark mouth maybe and then flop it to get the other half. That way it would be symetrical.
