slodogg62 Posted January 7, 2011 Report Share Posted January 7, 2011 if my wash isnt "running" properly, does this mean maybe i dont have a gloss coat down good enough? Cause i think my wash itself is good. Link to comment Share on other sites More sharing options...
ghodges Posted January 7, 2011 Report Share Posted January 7, 2011 It could be your wash isn't thin enough OR that it needs a tad more liquid detergent added to help it break the surface tension easier. If your wash is actually spreading outward from where you're applying it, that would be a sign of a thin gloss coat that's allowing the flat paint to soak up the wash. That's my best guess without you telling exactly what you're using for a wash medium. Best of luck! GIL Link to comment Share on other sites More sharing options...
slodogg62 Posted January 7, 2011 Author Report Share Posted January 7, 2011 It could be your wash isn't thin enough OR that it needs a tad more liquid detergent added to help it break the surface tension easier. If your wash is actually spreading outward from where you're applying it, that would be a sign of a thin gloss coat that's allowing the flat paint to soak up the wash. That's my best guess without you telling exactly what you're using for a wash medium. Best of luck! GIL Thanks Gil !! Link to comment Share on other sites More sharing options...
