JohnRatzenberger Posted September 15, 2008 Report Share Posted September 15, 2008 Guys, Need some guidance on the SdKfz 7 -- I'm building the Trumpeter kit and there are no paint instructions other than overall body color and, if taken literally, half the engine block. Seems there should be a little more than that ???? Did the old Tamiya kit instructions have anything worth while ? Are the new Dragon kit instructions out anywhere ? Next, can anyone point me at some photo sources for this vehicle -- what I really want are shots of the rear compartments open so I can see how to load stuff, particularly artillery gear, ammo, etc. Thanks in advance, Link to comment Share on other sites More sharing options...
TimDarrah Posted September 15, 2008 Report Share Posted September 15, 2008 John, I have the "Nuts & Bolts" #12 on the Sd.kfz. 9, 18 ton halftrack and it has drawings of them in all sorts of colour schemes. Remember that they left the factory in overall Dunkel Gelb and the Shokolaten Braun, Rot-Braun and/or Dunkel Grun were applied in the field by the unit's maintenance unit. It has a couple black-n-white photos of a restored engine and it's a dark colour but it wasn't black. I didn't see anything on hoe ammo was stored, sorry, but I bet it was in tubes inside the compartments. Timmy Link to comment Share on other sites More sharing options...
Guest Pyrman Posted September 15, 2008 Report Share Posted September 15, 2008 John, Trumpeter's kit is of the early version and, unless you're depicting a post-2/43 scene, should be painted in dunkelgrau. You could also add sandgelb (for Nord Afrika) or olivgruen (for Eastern front) as a secondary camo color. The engine blocks were cast metal, so any dark steel or oily black should work. The head covers should be a semi-gloss black. hope this helps... Link to comment Share on other sites More sharing options...
JohnRatzenberger Posted September 16, 2008 Author Report Share Posted September 16, 2008 Yes, I'll be doing a simple dunkelgrau scheme and realize that's what most the vehicle would be. Engine compartment will not be open, so only concerned about view from under. But what about steering wheel, shift levers & knobs, and especially the seats (leather, cloth, brown, gray ?) ? What would be the "inside" color of the "convertible top"? Thanks, John Link to comment Share on other sites More sharing options...
Guest Pyrman Posted September 16, 2008 Report Share Posted September 16, 2008 John, the steering wheel & shift knob should be semigloss black- IIRC, they were Bakelite. The rag tops were khaki, feldgrau or a buff. The early seats were tanned leather or faux leather. Link to comment Share on other sites More sharing options...
TimDarrah Posted September 16, 2008 Report Share Posted September 16, 2008 John, I've sent you photos of what you're looking for. I hope that they help. Timmy Link to comment Share on other sites More sharing options...
JohnRatzenberger Posted September 17, 2008 Author Report Share Posted September 17, 2008 Thanks Guys !!! Think I have enough now ... Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
