Maintenance Item help needed
Mark Aldrich
Below is a picture of the new Tamiya/Italeri maintenance set release. I am building this for the BoB group build. However, I think part B48 is a form of winch and needs more detail. As it is WWII I assume this is a hand winch. Does anyone have pictures or know of what detail needs to be added? TIA.
Mark
Mark,
Don't have a picture, but from the looks of it, it would be some sort of gear reduction thing with a chain hanging from the bigger end and another chain with a hook hanging from the other end. It's probably a gear reduction type thing with a cover.
Mark,
This looks like a chain pull winch. The type used to lift heavey objects. I could be way off base, but I think that I am in the ballpark. Looks like you will need to add the chain an hook.
Appreciate all the help and links. I now have an idea of how to make it look a little more realistic! John, Did you happen to make two???
Mark
