1/48 Lockheed EC-130V COAST GUARD project !
Jmarc
HI
  Here another project I been work on these day , it's modifying the TESTOR/ITALIERIE 1/48 C-130H to the EC-130V , at the moment I'm on the decals and adding the antennas , here is my last update :
..If you like to se the complete WIP on this project , I have set an GOOGLE page for it , just follow this link :
https://goo.gl/photos/jxfUh5Muw34MqsRY7
Enjoy !
  Jmarc
  • Like 3
2 hours ago, ghodges said:
THAT is going to be awesome and turn a lot of heads in that eye-catching scheme!
Thanks you are way to kind for may ego , it surely will when I'll be completed !
Oh very cool! I love the C-130 in any guise. One of my favorite rides! This one will sure be interesting to see.🤔
here is the update on the 2 on going C-130 projects ..You'le notice there is only one images available on each project , you can view more of the update picture of each projects on the Google link
PROJECT # 1
EC-130V version ...
(SEPT 15th)  ..Today , I completed the mid fuselage antennas and glued them into place and start working on the decal for the main radar structure  !
Like to view the complete WIP of this project ,follow this Google link ..
Enjoy and it's an 'rendez-vous' next week for more .on this particular project..!.
On 9/15/2023 at 2:19 PM, ghodges said:
Nice towel rack antennas! What glue are you using to not screw up your paint?
Thank youuuuu..first i set the front and back one with crazy glue to be sure everything is straight and after liquid ciment to be sure they are well glued on !
here is the update on the 2 ongoing C-130 projects ..You'le notice there is only one images available on each project , you can view more of the update picture of each projects on the Google link
PROJECT # 1
EC-130V version ...
(SEPT 22th)  ..Today , I continue working on the decal for the main radar structure  !
PROJECT # 1
EC-130V version ...
(SEPT 29th)  ..Today , I continue working on the decal on mid-fuselage and wings   !
PROJECT # 1
EC-130V version ...
(OCT 13th)  ..Today , I continue working on the wings decals   !
On 10/13/2023 at 1:31 PM, ghodges said:
It appears like you're applying the decals on a surface that's already been flat coated. If this is so, what method(s) are you using to avoid decal silvering?
It depend, usely several coat of SOLVASET , and if it not anought , a little liquid glue does the trick but be carefull not to touch it even if the paint is affected , usely the paint set it back o is own
PROJECT # 1
EC-130V version ...
(OCT 20th)  ..Today , I done the center fuselage between the wing antenna and continue working on the wings decals   !
PROJECT # 1
EC-130V version ...
(OCT 27th)  ..Today , I continue adding the wings decals   !
PROJECT # 1
EC-130V version ...
(NOV 03th )  ..Today , I completed the top wing decals and working on the balance one on the engines   !
EC-130V version ...
(NOV 17th )  ..Today , I starter the top fuselage decals and spray some white on a clear decal sheet using a mask !   !
(NOV 24th )  ..Today , I continue the work on the decals and done 2 rond tops antennas   !
EC-130V version ...
(DEC 01st )  ..Today , I continue the work on the decals and done the top antennas   !
(DEC 15th )  ..Today , I start to remove the extra white and retouch the COATS GUARD decals  !
