Stikpusher Posted May 12 Report Share Posted May 12 Well here I go again… another Patton tank… but not just any Patton, but the mount of “The King” I’m going to make Elvis’ M48A1 from GI Blues, turning this kit into this So far I’ve completed steps 1 & 2 and built the road wheels and basic lower hull Stay tuned for more progress updates…. Thank you very much 😉 Link to comment Share on other sites More sharing options...
Stikpusher Posted May 12 Author Report Share Posted May 12 Steps 3 & 4 now completed - bits added to upper hull, the upper and lower hulls glued together That’s enough for today…. 1 Link to comment Share on other sites More sharing options...
Stikpusher Posted Monday at 03:08 AM Author Report Share Posted Monday at 03:08 AM So I’ve made a bit more progress over the past few days… First up, I added the engine rear and top deck areas, the biggest visual difference between the M48/M48A1 and all of the follow on variants. Much closer is appearance to the preceding M46 & M47, than the A2, A3, A5 and M60 family engine decks… Then earlier today I added the road wheel arms, shocks, and final drive housings More to come in a day or two…. Link to comment Share on other sites More sharing options...
Stikpusher Posted Tuesday at 01:38 AM Author Report Share Posted Tuesday at 01:38 AM Had a short workbench session today.., I glued on all the road wheels and did the basic construction of the fenders. The sprocket wheels are test fitted but not glued in place until I add the tracks. I’m deviating fro. The instruction a bit now by concentrating on the hull before I start on the turret. The instructions by this point have you bouncing back and forth. Link to comment Share on other sites More sharing options...
Stikpusher Posted Wednesday at 01:03 AM Author Report Share Posted Wednesday at 01:03 AM Today I got in a few good long bench sessions and finished up the hull. First up I added the BII tools and PE detail bits to the fenders, glued on the tracks, then glued the fenders in place then later on I added the tow cables to the fenders, and the last detail items to the glacis area Now it’s all ready for priming the hull… I have another project that I want to prime, so two projects during the same priming session, and then I can start assembly on the turret later in the week. Link to comment Share on other sites More sharing options...
Stikpusher Posted yesterday at 02:27 AM Author Report Share Posted yesterday at 02:27 AM Since I had the airbrush up and running today, and the primer mixed properly, I also airbrushed on a coat onto the hull of this one after finishing with the Crusader AA session. I just left the driver periscopes undone as those are clear and I need to do an interior silver coat on those first. Now I need to start on the turret assembly… Link to comment Share on other sites More sharing options...
Mark Deliduka Posted 7 hours ago Report Share Posted 7 hours ago Yes! Nice work! This looks excellent in black as well! Link to comment Share on other sites More sharing options...
