1/24 Gemini with Rogallo Wing
K2Pete
This model is from the Revell 1/24 Gemini. I got it off of eBay and it was quite damaged so I rebuilt it, added a lotta scratch built details including the wing itself.
I weathered the crew module and the Nose details and landing gear were all built from scratch using styrene and Aluminum tubes and styrene bits and springs from ball-point pens.
The Heat Shield was painted ...
This was a really satisfying build ...   ;- D
Pete
Edited by K2Pete
I love it! I learned about this set up when researching my build of the Revell kit several years back. Great job on bringing this to life (in scale of course 😉)
Thanx Stikpusher! My main interest is in the early US Space program and Gemini still fascinates me ...
Here's a few more pix of the build ... I started with this broken up 'model' ...
Added the landing gear bays with styrene bits ...
... built up the RCS section using Aluminum tubes and a short length of plumbing pipe ...
then built the Nose landing gear ...
and the MLG ...
attached the NLG to the RCS section ...
... started to build the Wing ...
The 1/48 and 1/24 kit side by side ...
Test to see if the lines were nice and taut ... and it was done ...
Thanx for looking in!
Edited by K2Pete
Hey guys, the above duplicated image needs to be deleted. I've clicked on the "..." button, and edited text, but how do I remove THIS image?
I don't want to hit the DELTE button under the "..." menu, thinking that that may delete the entire post ... a little help please!  ;- )
Thanx
Pete
thank you for the additional photos Pete.
On editing, if you use your keyboard delete keys to remove the img or image codes, that should remove the duplicate image.
Thanx Gents! Stikpusher, if you wanna see the build thread, let me know and I provide link!
(I tried that to delete that image, but will try it again!)
Mark, this was NOT for the Mercury program ... it was for the Gemini program. It went through a good testing program and was determined to not be viable!
Pete
  • 3 weeks later...
Pete, here is the review build that I did for another site
http://www.spamodeler.com/forum/viewtopic.php?f=48&t=551
and the completed build on the same site
http://www.spamodeler.com/forum/viewtopic.php?f=87&t=3618
please pardon the photobucket photos… that was my old image host site for many years before their extortion scheme…
