IPMSUpdates
New Review: C-130 Tires and Brakes
Product Image
The Lockheed C-130 is a versatile aircraft. In production since 1954, the C-130J is the latest in a long line of models. The landing gear was designed for rough field operations, with large, low pressure main landing gear tires and a pair of low-pressure nose wheel tires. The original brake design was for a single disk (like in a modern car) and has been upgraded to a multi-disk unit. The brakes look the same once mounted onto the gear's axle.
The kit comes with 10 pieces molded in grey resin, and is meant for the 1/48 Testors/Italeri C-130 kit. There are many fine details with the castings. A nice touch is the "Goodyear" emblems and the valve stems and groove lines molded into the tires to represent the spaces between the treads. The only disappointment I found was with the brakes - I wish the back of the main landing gear tires was "hollow" so that the brake details would sit inside, just like on the real aircraft.
read more
View the full article
