IPMSUpdates
New Review: Eduard Brassin Tempest Mk.V Engine
Product Image
Eduard has released a great Brassin Engine set for its new tooled Tempest Mk.V which in its self is a great kit. This Brassin set is full of Resin parts and Photo etch sheet.
In the box is;
  • Approx. 77 resin parts
  • 1 x Photo Etch detail set
  • 1x Instruction booklet
Construction:
Stage A 1-4  is the assembly upper part of the engine, the only points to note here are that the location hole in R105 for part R100 is a little too small so needs to be opened out. Also the location hole for Parts 95 and 96 in part R105 is not the same shape so needs work. You will also need some wire to add in at points for various wires, I used very fine soldering wire which is very easy to form to the shapes needed.
read more
View the full article
