New Review: A-1 Skyraider 20mm Gun Barrels With Flash Hider & Pitot Tube
IPMSUpdates
Product Image
Guns and pitot probes on most plastic model aircraft leave a lot to be desired. There is often a mold seam down the center of the guns or pitot probe. Another set of problems are that the same parts, once cleaned up, are usually oval shaped in diameter, and the guns do not have that proper "hollowed" look of a real gun barrel. In some scales, such as 1/72, it would be difficult if not impossible to drill out these plastic gun barrels and pitot tubes.
Master Model has solved this problem with an aftermarket kit for the A-1 Skyraider. This kit consists of five metal parts, four gun barrels with flash hiders and a pitot probe to replace the kit's pitot probe. Each gun barrel is realistically hollow on the inside, with the thickness of the barrel in scale with the model. Master Model's parts are not unique to a specific A-1 kit, but are compatible with any 1/72 scale A-1 Skyraider kit, no matter which variant it is.
read more
