Wolfman63
Lighting your model with Fiber Optics and LED's Info.
I have received many requests on how I am doing the fiber optic lighting on my 1/350 USS Carl Vinson aircraft carrier. This is a step by step on installing the fiber optic lines. This can be done on any model. The first step is to drill a hole where you want the light to be. I am using 0.5 mm optic lines. The holes are drilled with a 0.5mm drill bit and are at a 45* angle so the lines will be flush to the surface on the bottom side.
20294306_10209802261120695_5781531174211
The next step is to bend the fiber optic line at a 45* angle with a pair of round tip needle nose pliers. You will need to bend the lines first. If you install the line without pre-bending they will not sit flat to the surface. You want the line to stick up around .2" above the surface on the light side. This is done so that the surface can be painted and weathered first. Once the surface is painted/weathered the fiber(s) can be trimmed flush.
20429779_10209802274121020_8280046109510
19875585_10209621109152009_7729482612468
To install the line, first make sure the line slides into the hole easily. The lines are glued in using acrylic gel medium. Do not use Cryo/superglue. The superglue is too stiff and causes the fiber optic line to become extremely brittle and crack easily. The acrylic gel dries clear and has some flex to it. This allows you to route/move the lines to the LED source without applying stress to the lines. I dip the entire end of the fiber into the gel and insert it into the hole. I then use a toothpick to make a nice fillet around the hole for strain relief. Finally a piece of tape to hold the line down into position until the gel cures.
20431680_10209802282561231_2156040771310
20476096_10209802296401577_7133340478466
Here is the acrylic gel medium I use. It is available and many local arts/crafts stores.
20431481_10209802312881989_4561296262021
Here is a picture of the lines after the acrylic gel has cured:
20376014_10209802298561631_2809975281409
The lines are then placed in a bundle taped and trimmed flush. A piece of 7mm shrink sleeving is cut and a 5mm LED is inserted into the sleeving. The fiber optic bundle is inserted into the other side flush to the top of the LED. The sleeving is then shrunk. NOTE: be very careful and apply heat quickly to shrink the sleeving. If you hold the heat gun too long you risk melting the fiber optic lines.
20140085_10209745536782622_5678429181124
Finally apply power to the LED and admire your results. Here is a picture of the flight deck runway and foul line. This is over 250 feet of fiber optic lines and 4 LED's (1 blue and 3 white) In the picture I have not trimmed the lines flush since the deck still needs to be painted and weathered. Also due to the camera and light levels, the optic lights appear much brighter then actual.
20292827_10209802411204447_7447416234894
To show an example on using fiber optics and a micro LED, Here is the frensel lights for the carrier I made:
19875223_10209568499196793_3671837782215
I bought all my LED's from: http://www.modeltrainsoftware.com/ledlights1.html
All fiber optic lines were from: http://thefiberopticstore.com/
They have many sizes from 0.25mm up to 3.0mm
I hope this information will help you if you want to illuminate your model.
I am still learning tips and tricks for lighting, I will answer any questions that I can.
Edited by Wolfman63
This is good information as I want to light the eyes of my "Death Dealer" model with red LED's. Thank you.
Really nice write up. You covered all the typical questions that come from these ahead of time, like where did you get "that" and where did you buy "those"! I'm building the USS Enterprise in 1/350 so I will make use of this for sure.
