Rosewell Alien Tribute
I always have at least 2 kits going at the same time. while I was waiting for parts of DeNiro to dry I got to work on this little alien kit. Super simple and quick to finish -
(This angle is for a good look at the crashed saucer)
Thanks for looking. As usual, CCs are welcomed.
Thanks.
I got it from a garage kit guy, Gillman Productions. You can find him on FB.
Really nice painting too. The hint of colors below the skin is outstanding.
Thanks. I used one of 2 "techniques" the GK guys to do bring the skin alive. One is to flick tiny drops of many colors of paint on the skin and then lightly do a top coat to settle the drops underneath. I first saw this watching Rafael Robledo work - https://youtu.be/tQizFgzbvYY
BTW, This guy is absolutely amazing.
But I can't get the dot of paint tiny enuff so I do the older technique of just doing squiggles all over the skin -
I used red, blue, yellow, green and a little purple over a light gray primer. I Spray a clear coat after every 2 colors so if I screwed up the last color and I need to remove the goof, I wouldn't go all the way to the base or even worse the primer coat. Rafael suggest a clear coat after every color until you get used to the technique.
After the last clear coat was dry I hit it with the flesh color, but making sure not to apply it too heavy so that all the other colors disappear. It's tough to know when enuff is enuff - so go slow.
Wow...that is excellent! Thank you for sharing this picture and the information!
Nailed the sickly gray-green skin color! Also, how did you do the eyes? They look flawlessly glossy.
Thanks.
The skin color is Vallejo's Gray White or is it White Gray over light gray primer and the squiggle technique I described previously...
edit: I looked and it's White Gray. The paints are arrange by a position number on the rack at the store (and my paint rack at home). :smiley2: They are grouped together that way rather than by their stock numbers which are all over the place. So the White Gray is 151.
I hate to admit the eyes are done simply with black paint and a brush. I almost never use gloss paint, but Vallejo has a Gloss Black that goes on VERY smooth. I won't say it's self leveling, but it appears to me to do that.
You're quite welcome. I have no secrets, so if I can pass something on and help someone else, it's all good.
If you really like Figures, I would definitely subscribe to Rafael's YT channel. IMHO he's better than amazing.
  • 2 months later...
Put a curly haired wig on that thing and I think i dated it in high school. Jeesh, I'd have gone out with anything that would have me.
  • Like 3
  • 3 weeks later...
Hehe you and me both. ;)
